goldhunter_2
ok I tried the search nothing seem relevant in my search to this issue. I have two how to questions.
1) my clutch pedal is all the way up on floor spring does pull it back and there is roughly 1/4 travel before engage clutch arm because the hole in linkage is worn . I mite be able to drill and put a space in there going to see if can find shorter an thinner bushing in town . Either way I think clutch needs to engage little more because of problem I have with forward gear grinding question is do I turn the adjustment fork out or in to do that?
2) How to adjust Forward gear , it is actually a chain linkage so no adjustment. issue I and have is 1-4 and Reverse work great, Forward works when/if you can get in gear but grinds most time and pops out of gear when let off clutch. There is some wear in the pin holes of shafts (see picture) but not enough I can put a bushing and can't get drill in there to make bushing fit. My thought is the clutch needs adjustment , but I am not sure if there is some way to adjust the Forward gear also?
