Huber Won't move
JTWAT
Central FLA
No, I have a leak at the top of the pump where the control cable connects. I purchased a pump seal kit and waiting for it to arrive. I connected a test gauge to check control pressure to the pump but don't get any pressure from the pump side. The hose I removed from side of the pump is spitting foamy oil but nothing from the pump itself. Not sure where it's getting air in the oil. Still looking for a shop manual. I have found one for the pump though.
JTWAT
Central FLA
It is, It looks like no one uses them anymore and has thrown out all the manuals. I keep checking ebay but no luck so far. I'll just have to figure it out myself the long, hard way I guess.
materthegreater
VT
Have you had any luck with this? My Huber has been hibernating under snow for the last few months.
hlc123
dongguang
Your situation (a hydraulic whirring sound, a brief movement followed by a stop) usually indicates that the system has pressure but cannot continuously build up or maintain flow.
JTWAT
Central FLA
I decided to remove the pump and take it apart. I have a new charge pump for it. Waiting for a bearing before reassembly. It did not look too bad inside for it not to work. I also have a repair manual for it from Sauer Danfoss. Relief valves were working so we will se what happens when I get it back on. I may rebuild the hydaulic motor too. All the hoses are shot so replacing all of them.
cuttin edge
NB Canada
Finish grader operator
Does the mold board roll ahead and back manually or hydraulicly on these or just solid
JTWAT
Central FLA
I found a service and repair manual from CMI equipment. I will attach it if anyone needs it.
  • Huber Maintainer M850A (Maintenance & Repair)-1.pdf
materthegreater
VT
I called Huber Maintainer to ask about some parts and I'm considering buying a parts book also, mainly for the diagrams. Do you find the diagrams to be helpful?
JTWAT
Central FLA
Very helpful. It is a breakdown of how the parts are laid out and comes in handy when reassembling.
I found my parts book on Ebay. I think there is another one still listed.
