Graham Hamilton
My machine (E3G00727) has a hydraulic leak on one of the small hoses that heads back to the tank and connects into a large pipe that goes between the bottom of the cooler and the top of the tank (photo). I had to take off the counterweight to get access to it (photo). The tank end is easy enough to get to but the other end disappears into a channel (with 3 other hoses and 3 cable bundles) that goes round the back of the engine. I think this reappears behind the pump and I’m guessing goes under the seat towards the spool valves, swing motor etc. I’ve lifted the floor plate to try and find the other end (photo) but it is packed solid with hoses and cable bundles and not obvious. Also the swing motor is under the seat/relays /fuses/heater etc
I’m looking for advice about what to do next to track the other end down. Or perhaps should I be looking at a field repair on the hose end I can get to.
Advice much appreciated.
