Marc51
I have a 2015 Komatsu PC55MR-2. Its an offshore machine.
There are 3 things that aren't right with the machine. I am not sure if they are directly connected issues so I will lay them out seperately.
Issue #1 - The control valve for the dozer blade is malfunctioning. ( I have ordered a used replacement.) Currently the pressure is bypassing the valve and it allows leak down when the blade is up (and no down pressure). Essentially it is circulating fluid = wasted power.
Issue #2 - The hydraulics all work normally but at a slightly lower speed, I blame issue #1 for that.
Issue #3 - When the hydraulic cylinders on the machine reach their maximum or minimum stroke (in or out) the machine continues to try and push fluid. If I hold the control a little to long I can hear the hydraulic pump draw down the engine and if held too long it will stall out the engine completely.
Should the extra hydraulic pressure even be there? Once maximum or minimum cylinder stroke is achieved, should it just bypass that extra pressure and return to the tank?
Not sure where to start looking. Do I have too much pressure? Why am I able to keep pushing pressure into a cylinder and stall the machine?
