Hyster 30, Vintage Unit Value?
Flat Thunder Channel
Ohio
Does anyone know the value of these units? I am looking at an old Hyster forklift. I think it has a 4 cylinder continental propane engine. I am debating trying to purchase for my home shop. It appears from the pictures to be a smaller unit. Which works perfectly for my small garage. Thanks in advance for the help / info.
John C.
Last time I looked, you could find plenty of units like that at auction for less than $5,000. Does that have an manual or power shift transmission?
Ohio
I'm not for sure. I think I see a third peddle. So manual? I am going to look at it this afternoon and potentially make a offer. I know it needs a little work. I am betting the brakes do not work at all and it stated that some minor hydraulic leaks exist. It does have side shift which is a plus.
mowingman
SE Ohio
Retired
I bought one very similar to that about 10 years ago. It was old, did not look pretty, but would still do the job. I paid $2500.00 for it at that time. With the small solid tires, you can not use it anywhere except on concrete paved floors. So, if you happen to want to take it outside onto a gravel driveway, it will not work for you. I might go $3000 now, if it is all in good operating condition. Around here, there are always a lot of that type of machine for sale though.
Andy1845c
Southern Minnesota
Electrician
https://minneapolis.craigslist.org/hnp/bfd/d/minneapolis-forklift-for-sale/7109709240.html
https://minneapolis.craigslist.org/ram/tls/d/red-wing-1952-yale-forklift/7108275731.html
https://minneapolis.craigslist.org/hnp/for/d/rockford-hyster-forklift-lb-capacity/7107014019.html
Couple ads off craigslist from my area for comp. Those older forklifts come up cheap if you're patient. I wouldn't pay too much for one. I have an old Allis Chalmers forklift a little bigger than that Hyster that I think I paid $500 for. It needed a ring gear though.
I'm on the taller side and find those small older forklifts like sitting in a clown car. Worlds better than no forklift, don't get me wrong but ergonomics weren't a thing back then I guess.
I also second what mowingman said, they instantly get stuck in gravel and weigh enough they aren't easily unstuck.
Ohio
Well I'm the proud new owner of a project. She needs a little fixing up! I just got it home today. Reverse is a little tricky it doesn't want to engage unless you hold up on the pedal. Need to investigate how this unit functions. It has a hydraulic transmission. It switches a solenoid valve with a selector know on the column. The brakes are also none existent. I am like a kid with a new toy.
Thank you for all the information. I bought this unit on the cheap and if I can fix those known issues I think it will do the job. I only plan to use it in the garage. It did come with a custom made set of pneumatic tires that supposedly make it more forgiving on gravel, but I don't know if I'll try it.
'When you have too many projects.....Add another one'
Ohio
Excellent information! I wish mine looked as good as the second listing. I think they are very similar if not the same models, except mine has a little patina. Thanks
Ohio
Ohio
If anyone has specific useful instructions, tips or tricks on servicing this unit please share. This will be my first forklift project. Thank you in advance.
Currently curious what type of ATF fluid the transmission takes and where the fill is located? I found the dipstick, but didn't look hard enough for the filler.
Ohio
Step one. Move enough stuff out of the way so the garage is functional again. *Note I didn't realize a forklift specific area was available. I will post more info, updates and questions in that area. I hope to learn more about these units through other people's experience and knowledge. Thank you
