Hey all, my first post here so many thanks in advance for your help. Im located in Ottawa Ontario Canada
So I have a 2000ish Hyundai HL730-3 wheel loader with Deutz liquid cooled engine that has a bad vibration, so I want o install a low time Perkins 1004-40T that I have into the loader.
Currently, the engine is connected to the torque convertor by a drive shaft, so the engine flywheel has a vibration damper plate attached to it which is attached to the driveshaft which is attached to the torque convertor. The driveshaft only has one u joint on it and a mounting plate which bolts into the damper on the flywheel.
So my issue is finding a damper plate that fits to my perkins flywheel and I'd like to use a 2 joint driveshaft because there is no way I'll be able to line the engine up with the torque convertor...I know me.
I'd use the deutz damper plate but I dont have enough room to make a shaft with two joints that bolt up to the plate.
Anyone have any ideas for parts or a way I can make this fit up?
Pics coming, thanks!
