Pep Joe
My client Bobcat S175 traction solenoid won't pull and hold even after pressing the "press to operate button" on the left hand panel and the cross bar is down.
Usually when the "press to operate switch" is pressed when the cross bar is down, you will hear a sound that the traction solenoid has pulled.
Now I'm suspecting that the traction solenoid is not getting the pulling and holding current to enable movement.
My big problem now is that I can not trace where the pulling and holding wires are supposed to be getting current from.
I have checked all the fuses and relays. All fuses are having current. The fuel shutoff relay is not getting current to the relay pin "86" and so the fuel shutoff relay is not energizing to get current to the traction solenoid pull wire.
I can not trace to know where all the traction solenoid wires are coming from because I don't have the electrical schematic for it.
Model: S175
Sn: 530114236
Model: S175
Sn: 530114236
