I have a new ASV RC 30, which I love.
My problem is the case drain for the auxilliary hydraulic circuit. The little metal button seems to be stuck down. I fear this may be the reason my grapple seems to require constant "opening" while rounding up material.
Since I've owned the aftermarket rootrake/grapple I purchased for (an unbelievably low price) I have wondered if it was just the geometry of the top clamp and the weight and the bouncing around that made it close by itself. Or maybe it was the cylinder leaking. Having disasemmbled the cylinder, and an experienced mech relay he didn't see any reason why the seals might leak past, I've sort of discarded that as a problem. I did so because some of the cheaper brands of cylinders had the backer nut loosen up. Either way, I doubt its the cylinder now.
Shouldn't the clamp stay open while traveling and collecting? If the case drain is stuck open, would it still operate at all?
I believe every other grapple Ive ever used had no problem staying open. then again, I think they were machine matched high-end accessories...
I'd like to believe that the clamp ought to be able to apply some serious crushing power to brush, but I am cluelss as to how to guage its ability. I can round up material, I can hold onto logs with the bucket tipped out and the clamp doesn't open, but I have a feeling it barely does it compared to the expectation that I ought to be able to crush certain size deadfall.
These troubles notwithstanding, I would recommend anyone looking for a Rootrake/grapple to this company. I doubt its the rake's problem, and the price is very affordable. Out of repsect, I will not pimp their name out loud. You would need to send me a PM and I will be happy to relay, just to help out someone else. Certainly, I have no tie to the company
I appreciate anyones input. I am a fair hand with tools, and read well. but I have had just about zero results in tracking down a troubleshooting guide that can shed light on the subject.
Thanks
GeeVee
Thanks
GeeVee
