Dave Neubert
anyone have any info on timing the Bosch VA injection pump before removing it
Gee, I was about to suggest they contact you.There’s a side cover plate on the pump.. remove it & let it drain..
You’ll see a pointer w a flat on it..
Rotate the engine by hand until a small line comes into view and lines up with the flat on the pointer.. then check the degrees on the flywheel.. most I’ve done are 19*btdc.
