Iightest excavator to lift 1.5 ton
Volvomad
Ireland
I am looking to lift 1.5 ton gabians with a chain just off the ground , swing 180 degrees and drop them again . The coupler will only need to lift to 7 feet above ground with 4 foot cubes at a distance to just clear the machine .
Space is tight ,very tight . Would a 10 ton zero tail handle this?
hosspuller
North Carolina
According to CAT"s website, at 20,000 pounds, you're looking at mini excavators. CAT's small excavators start over 20k.
The other issue is the 7 feet coupler height. The boom and stick of a mini will have to be extended to get the height. That pushes the load away from the center.
I would be interested in what you are able to find.
Just for reading here's a link.
https://www.constructionequipment.com/when-excavators-and-backhoes-become-cranes
Depending on the distance you're moving the loads, a larger excavator may be a better choice. Then the lift is only an arc in front of the machine instead of 180 degrees.
hosspuller
North Carolina
Volvomad … Just looked at my Deere 310C TLB lift capacities ... It would do your job. Weighs just 13,000 pounds. Of course with the stabilizers down it's 9 feet wide
Volvomad
Ireland
Would that have a similar back bucket capacity as a 6 ton 360 . It has to be a 360 .
I had to google the specs . We dont get deer hoes over here . Nice looking machine
hosspuller
North Carolina
How much distance between the two gabians ? Maybe mount a jib crane on a vehicle?
