Injection pump removal
Angry Mike
Wyoming
Hey all, have a perkins 404D-22 on a genie lift. Its a cassette type pump and the instructions say to loosen bolts , lift it and remove a clip for linkage. After loosening bolts it barely comes up off the block. Anyone run into this problem?
thepumpguysc
Sunny South Carolina
Master Inj.Pump rebuilder
If it has an electric shut off that screws into the left side of where the pump lives, u gotta take it out 1st..
U also have to hit the cut-out in the block that will allow the rack to pass..
If it’s still confusing, look up a Kubota inj pump removal video on utube.. it’s explained a little better there.. good luck
Angry Mike
Wyoming
I got it. Was just really really tight fit lifting off the studs from plunger spring pressure and i didn't want to hulk it.. thanks
Angry Mike
Wyoming
the pump shop i ordered a replacement from wants it back for a core.. plunger was siezed and the bore is pretty scored up
