lonelyowl7
Hey I have a cat 267b that needed head work, so I had to remove the injectors. They ended up being supper stuck and had to bang 2 out from the underside of the head.
Fast forward, head is all redone, back on the engine, with new injectors, went to turn it over and I hear a large compression leak when turning over, and its coming from one of the injectors. I put anti-seize on them and I could see it blow some of the anti-seize out.
I took the injector out and noticed the seat is damaged in some way, almost like the old injector took a small piece with it.
Its kinda hard to get a picture of it but you can get the idea from that.
I thought it was just a little bit of dirty water or something when I originally saw it, so I tried to clean it but its definitely a missing material.
I found an injector seat cutter/clean kit online and was wondering if anyone has used one and if they have any advice, especially how to keep metal pieces out of the cylinder. I'm probably going to order this one.
Thanks for any help!!
