Acoals
Cat 305c, HWJ01191
After sitting for a week, the machine would crank but not start. Took lines off and blew through, pressurized tank, ect, no good. I used a temporary fuel line to bypass the filter assembly, pressurized with air, machine started. Ran it onto the trailer and brought it back to the shop. I replaced the fuel filter and replaced all the o rings in the filter housing. Machine started but had a miss. Shut it down, started it 15 minutes later, ran fine.
Ran the machine for a couple hours, and then it starts bogging and stumbling. I replaced the fuel lines from the tank to the lift pump, ran good, finished the job I was on, about 2 hours. Next job machine runs a couple hours and the problem returns. I had a lift pump for it, so I replaced that. The new lift pump sounded louder and stronger, and the machine ran well . . . for a couple hours.
At this point the fuel tank has been drained and inspected, the pickup tube inspected, all the rubber fuel lines replaced, the filter assembly re sealed and the lift pump replaced. The machine will run like a top for a couple of hours, and then start stumbling and bogging out, at times it can be restarted, give it some throttle and it will be ok for a while. The problem does seem to be worse when the machine is hot and ambient temps are high.
I don't know much about injection pumps, and I sure don't like throwing big money parts at something without being sure that is the problem, but I am not sure what else it could be at this point. Am I missing something? Could an IP failure be intermittent like this?
