RBH
I have a Cat. 1993 D4C with a 3204 engine. The block is messed up and I can not find a block anywhere! Does anybody know if any other Cat engine would have the same bolt pattern to bolt up on my machine (1993 D4C)?
You will have better luck looking for a 45Z 3204 engine ,That should be the serial number of your engine.I have a Cat. 1993 D4C with a 3204 engine. The block is messed up and I can not find a block anywhere! Does anybody know if any other Cat engine would have the same bolt pattern to bolt up on my machine (1993 D4C)?
