John V
Hey, I just swapped an Isuzu 4jb1 into my Ihi excavator. 4jb1 manual says the oil delivery pressure is about 56psi. I have the machine hot wired to get it to run right now (big wiring mess to sort out), so I have an analog pressure gauge hooked up to read the oil pressure. First start up in the morning and it reads about 70psi. From there it gradually drops down as it heats up. After about 15-20 min, it steadily runs at about 20psi. Is this too low? What should I first look into if it's not acceptable? I did change the oil and filter after swapping the motor in.
Thanks,
John
Thanks,
John
