I have been unable to find the engine serial number. Our local dealer says Caterpillar doesn’t have it in their records.
I did get the arrangement number 1017528.
Cat has advised me there is a factory reman located in Alabama for $22,000.
The 101-7528 engine Arrangement Number is unique to the IT28F, it's used in no other model.
Your local dealer is correct. No engine Serial Number appears in the system for your particular machine.
After having looked at a bit of engine data I reckon there is a good chance that the original engine is one of three, all Arrangement Number 101-7528, that were built around that time frame but were not allocated to a specific machine. The Serial Numbers are 98Z02279, 98Z02285, & 98Z02292.
Now I could be wrong and all three may have been built for the Parts System but my bet is that one of them is quite probably in your loader.
What Part Number of Reman engine is the dealer offering for $22k.? 10R-7258 or 0R-4881.?
A last curve ball. If there is no sticker on the valve cover bearing the engine Serial Number, and neither is there a plate on the cylinder block with the same number, is there any possibility that the engine currently installed is in actual fact
NOT the original OEM engine that was in the machine when it left the factory..?
