kevink,
i have maxed out factory recommended speeds on cones and impactors. results are increased production, increased wear and higher shaft and bearing temps which will result in shorter life overall for the entire machine. expect the same from speeding up the jaw. also a good side affect of speeding things up along with higher production is the particle size is over all smaller, what occurs is each rock gets hit an additional amount of times while it is in the crushing chamber......TIO
