I would think an issue with the vacuum booster
Yes. Pedal is hard with engine off. Yes I lubed pivots.Does the brake pedal get hard when engine is off? Have you lubed the pedal pivots?
My booster used to freeze up in winter time and I'd spray lube inside of it to free it up.
It's the booster, when I unhook the vacuum line with engine running, the pedal returns to the top. When I hook hose back up, it pulls the pedal
