Cheeseman70
I have a JCB 541-70 Agri Super. It has the six speed power shift transmission. The emissions system was deleted before I bought it. I've used it multiple times per day for several years and there has been an intermittent problem that has been getting much worse. The error code P172E-00 comes up shortly after starting and the transmission will not work while it has that error code up. It basically 100% of the time only comes up after starting, never during use. It used to be that the error code would go away after idling a short time, sometimes just a few seconds to maybe a minute. Now it basically throws the error code at each start and sometimes it takes over 15 minutes before it goes away and I can use it. It works as normal when it works. I have tried revving the throttle, rocking the machine with the loader, and moving the machine with the telescoping boom and nothing seems to help the error code go away.
I purchased this machine several states away form someone that supposedly buys JCB (and maybe other brands) from overseas and uses and resells them.
I used to have a local JCB dealer 45 minutes from me, but the dealer ship closed and now my dealer is 2 hours away. I had them come out on a separate issue which involved going into the computer and changing a setting, but I didn't realize when I called them that they would not be able to do anything because it had been deleted. I spent about a $1000 to find that out!!
Does anyone have an idea what I should look for?
Serial number JCB5TBYJE02173737
