JCB 803plus (2004) - Hyd fluid replacement
Ed Dixon
Uk
Hi All.
I recently inherited a JCB 803plus and need to change the hydraulic fluid as it had a bad leak which i have fixed with a replacement hose.
I bought a new hydraulic filter (woah expensive !) ready to do the change. Before i dropped the old oil out i thought i would check to see if i could release the cap at the top of the tank. I removed the 'dip-stick' cap from tank to vent any pressure but could not shift (what looks like aluminium) cap that would reveal the filter. Didnt want to put too much force into removal until i checked in with you guys to ask if anyone has a service guide for this job, or tips on how to remove the screw hatch.
thanks very much in advance for any replies.
regards
ed
uffex
Lincoln UK
Admin
Good day Ed
I have a contact with the operators manual if that helps, providing the pressure is released I would suggest leave it be.
Kind regards
Uffex
Ed Dixon
Uk
Thanks Uffex. Can you explain what you mean “leave it be” ? I would like to change the hyd oil and filter as it’s had a bad leak and I suspect it’s lost at least 10L of fluid, but can’t see where else the filter would go except for inside the aluminium looking screw cap on the top of the tank. That is really tight.
Cheers
Ed
Ed Dixon
Uk
E14F327F-542C-4C41-A851-A08CB8BE6E5F.jpeg Hi. Here is a photo of the top of the hydraulic oil tank. The ally screw thread will not budge. How do I get at the filter ?
thanks
uffex
Lincoln UK
Admin
Good day Ed
See what you mean bite the bullet and get tough if it busts I have posted a link for a new one.
Kind regards
Uffex
It appears as though the cap engages into an internal thread in the filter housing body.
Clean off all the oily residue around the area first, hit the body of the filter housing with a blowlamp or similar heat source, then whack the ***k out of the cap..?
Ed Dixon
Uk
Thanks guys. I will heat carefully and shift it with a large set of stilsons and a tube. Thanks for the link Uffex to a similar replacement part if all goes bad !
