equip guy
- Joined
- Nov 17, 2010
- Messages
- 95
- Location
- Massachusetts
- Occupation
- Ag and Construction Equip mechanic
Hi fellas, today I was working on a JD 450c dozer that had a blown head gasket, machine is from 1980, I took pics today but haven't down loaded them yet. After pulling the head I noticed that approx 80% of the coolant passages on the block and head were closed up with heavy rust scale. I'm leaning towards the gasket failure due to restricted flow. The unit has 1400hrs on it and the last coolant change was in 2004 from what was listed, my question is this, after I cleane out the ports on the block and the head what do you think I should use to clean out the rest of the block. I have heard of acid based descaler cleaner, but do you think this might make a woese problem if there problems on the liners? I need to have this machine in service by next tuesday for a time sensitive job. I hate to put it back together as I wanted to pressure check with the head on and the oil pan off to see if coolant was pushing through the liners. I can revisit the issue in a couple of weeks even though I have to undue all that new work. ( I know it's stupid, but cust wants it slapped back together for job), Due you think if I descale that it might cause worse issues before they use it? Do you think it would remove all scale too. This would have to be done in chasis. Any suggestions would be appreciated. Thanks
