Knivens894
I have a 409E with about 8,000 hours which suddenly went slow in all modes. The problem was no more than 2,000 PSI from main pump. Removed main pump for internal inspection by hydraulics shop, no issue found. During 4 months of searching, Replaced:
1. Main Pump solenoids.
2. Angle sensor
3. DP Sensor
4. Fuel filter
5. Cleaned hydraulic filters, air filters
6. Replaced PVC
7. Cleaned all connections
8. Service Tech finally showed up and found a broken spring in one of the main pump solenoids. Replaced that solenoid. Max main pressure then 3,800.
9. Tech returned and said engine injector pump was not meeting specs. Removed and had engine injector pump overhauled with no improvement noted. Tech says no issue with PVC or its sensors per his computer.
10. Overhauled the system main relief valve and replaced the surge relief valve with new. This allowed adjustment of surge and main pressure specifications.
Thinking I had solved the problem, I attempted to return the machine to service. Functions are weaker and slower than before with the engine wanting to stall. Operating temperature soon rose to near red line. The hydraulic oil was so hot steam came off the bucket cylinder when digging in water. I believe I have a hydraulic by pass somewhere. My question is how do I find it? Is it trial and error, or is there a methodical way to find it?
Any and all experiences and/or suggestions, short of throwing a match on, it would be appreciated.
2. Angle sensor
3. DP Sensor
4. Fuel filter
6. Replaced PVC
