Jordy
Good evening I recently purchased a jd 490 D excavator and bought an kit to add auxillary hydrauilcs to it. I have the kit all mounted but appear to be having issuse with the hydraulic control bank. (Not sure if that is the correct term but anyways beside the cab where all the hydraulic come out of to control every thing) anyways if I understand the sytem correctly the soleniod opens and sends oil to the control bank and opens the valve for the oil to flow out to the attachment. I have oil coming out of the solenoid which goes in the top but no oil coming out of the bottom hose which is the return line as well as i have no oil going down the boom to the attachment. I have tried adjusting the flow as well as the pressure and cant get anything to happen. Is there anything that I am missing or any thing that i need to remove like a blocked port somewhere when you add aux to these machines? The company that sold the kit to me said it could be on a older machine like this the valve inside could be stuck. If so how hard is it to take the hydraulic bank apart? Thanks in advance Jordy.
