Midnightmoon
while testing CAN resistamce on a 700K it appears the can resistors are electeonically controlled by the ECM on that given CAN network but i need confirmation.
while testing resistance at the dash display the display has 50 ohms when unplugged and the wiring to it acted odd. 1.7ohms with power off unpluged from display but if i cycle the power on then off it has 120 ohms a few seconds after it powers off with display disconnected then goes back to 1.7 ohms. is this normal? it appears display risistance should be 120 and the display is bad because if it has a resistor 50 ohms means its bad but maybe jd is a different beast. can anyone confirm?
