The dozer will only move when taken out of park, and it doesn't happen every time. It's very random. If it does ever move when taken out of park when it stops by itself it won't move again.
No codes, I fixed everything pertaining to the ones that popped up. Only one that might still be left is f621 but I adjusted the right track speed sensor so not to concerned about that.
I used acs industrial services out of north Carolina to fix the tcu. They guaranteed it with a 2 year warranty so I hope they knew what they were doing
While trying to recalibrate the tcm. Holding the button down as well as the decelerator pedal, start the engine. Let the button go. Screen will pop up with tcu software 600, then 11, then p, move the park lever down and 45e pops up. 45e is supposed to stop flashing before you let up on the decelerator pedal but doesn't stop flashing until you let off the decelerator pedal. You can then progress no further than this.
All the rotary sensors for the controls all seem to be within spec range but reversed of what they're supposed to be. (So forward voltage reading should actually be reverse and vise versa)
The only thing that doesn't seem to work from what I've found is the rpm read out. The hydrostatic speed sensor tested within spec, pin 17 to the back of the monitor tested the proper 14v. That leads me to believe the monitor is screwed up or something with the tcu?
