jonno634
On an old JD tractor we had it was common to lose the intercooler, is that an issue on the 892E? I haven’t noticed water in the oil (but it is a little over full, and thought when I changed it, it was right at full), no water/antifreeze drains off of the bottom of the pan and there is no oil in the water. The radiator has been low and I am not sure where the water has went, checking the hose to the burp tank and the burp tank itself. But this got thinking about the intercooler and at 12,xxx hours wondered if that was a thing I should consider doing like we learned on the tractor should be done at 8k hrs.
Engine S/N: *RG6076A558048* 6076AT030.
Thanks, Jon
Thanks, Jon
