ABruso
Hi all, I have a John Deere 332 track machine. It's been running great since I've had it. It is my second machine, but 1st diesel one. I had not drained the fuel/water separator it in a while, so it drained quite a bit of liquid. It looked like watery fuel. After it finished draining I closed it up. I started it, it ran for 10 seconds then just lost engine power down to 0 rpm. I can't start it now.
The water separator has a primer button on top and a fuel line bleed screw. I tried priming and bleeding a lot of different ways and nothing worked. I even pumped the primer what seemed to be 50 times. I also took off the water separator and it was filled with fuel in the center like it should be.
Not sure what color the exhaust is cause I was alone and it was dark out. Is this a clue?
The directions said nothing about having to prime after draining the separator.
Whats my next step?
Whats my next step?
