tool_king
Hi Guys
Working on a JD TC54H Tool Carrier transmission with no forward drive for a friend . Loader serial is DWTC54H576781 Owners guys tried a new FNR handle .Being the loader does a like of forward /reverse all day long . But no luck .Loader had codes 1653 for no ccu transmit ,599 for coolant temp 396 trans oil temp high and 478 oil pressure circuit voltage low .
The guys replaced the trans cooler thermostat already . Was able to clear the codes but the 1653 is still their .Went throught the wiring all seem to to be good on continuity from dash display to trans controller and to loader controller . Even tried spare controllers and dash display from another loader .
Did pressure checks forward low clutch has 244 psi and forward high clutch has 0 psi .
Anyone ever run across this ?
thanks
Ed
thanks
Ed
