Kap450
I have a late 60's early 70's JD450. I ran it out of fuel the other day. According to the manual you need to prime it with the lever on the side of the fuel pump to fill filter #1 then filter #2 then loosen the fuel solenoid and prime till it flows with no air bubbles. I have noticed that there is no pressure on the primer lever. Is this normal or is there a problem with the fuel pump. I have been able to prime filter#1 and have pulled the primer lever 75-80 times trying to get fuel to filter # 2 to fill with no fuel coming out. Is this normal? Wil the fuel finally come through if I keep pumping? I have replaced both fuel filters.
