JLG 40H rough running.
excavator
Pacific North West
I've been working on a JLG 40H with a Ford LRG425 engine. It acts like the timing is retarded, runs rough with no power. Then it will occasionally back fire after which it will run smooth with lots of power. Then after shutting it down and restarting its back to usual. Any ideas on this one? I quit working on gas engines back in the 80's long before DIS came out so this one is a bit perplexing.
barklee
ohio
I believe there were computer problems with the late 90s early 2000s ford LRG engines..... They came out with a computer and harness update kit that corrected several problems. You may have this sort of thing going on, others on here know much more about this than i do though.
excavator
Pacific North West
So I finally was able to get back to this machine and have determined the ECM is bad. I've checked prices and the owner's not real anxious to spend $1500.00 to replace it. Has anyone found any other modules that might work? The JLG number is 7023687, I'm also looking for the original Ford part number if anyone knows. Thanks again.
excavator
Pacific North West
I ordered the ECM update kit from an industrial Ford dealer and installed it this morning and that cured the problem. Thanks barklee for the heads up. If anyone needs the component part numbers I have them.
Bte238
Saugerties
Could I get the part numbers from you I am having the same problem now
Could I get the part numbers for the jlg ford 425 I am having the same problems now with my lift
Thanks
