mdnelson86
I've got an old JLG 50HT boom lift I use around the farm and it's started having some issues I'd like to resolve. Biggest problem right now is that sometimes it gets stuck in its' high idle position even when I take my foot off the dead mans switch in the basket.
Normally when you press on the switch it revs the engine up and allows hydraulic control. Let up off the switch and it idles back down and you none of the controls work. When it sticks it just stays in high idle and doesn't allow any of the control functions so that would sound to me like it is working alright between the basket and the main frame. This doesn't seem to be consistent as sometimes it will work and other times it won't. also doesn't seem to be related to any certain activity. Sounds to me like possibly a sticking solenoid somewhere that controls the throttle setting. any ideas where that is? I've tried tapping on everything I can find to see if something is sticking but haven't had any luck. it has the 4cyl ford engine.
