dieseldogg
I've just recently bought a JLG 6o GR boom lift that has seen little use and always has been stored indoors. It appears to be in excellent shape and everything works except for a couple problems that I have encountered. One issue is that when the boom goes above horizontal the engine will drop to a lower rpm like it should but the engine will really struggle as the boom raises and will eventually die at around 20ft. The engine will also struggle and die if I swing or boom in/out while above the horizontal plane. Once the engine dies, the auxiliary power will work the boom in/out and swing but not boom down. I have had to walk down the boom a couple times now and would really like to figure this one out before I break my neck. One other issue is with the drive. I know that 2 whdr machines are limited as far as mobility goes but mine really seams to have no torque. It will go forwards and back and the high speed function seems to work (judging by listening to the engine) but unless going downhill it wont move. Where I am trying to use this machine is level hard packed ground with the occasional slight dip that the machine wont pull itself out of. Any help with any of these issues would be greatly appreciated. Rick
