We recently had our hydraulic pump fail on our John Deere 120 excavator and replaced it with a rebuilt pump. Currently the machine has no hydraulic functions working with the rebuilt pump.
Prior to the rebuild, pump 1 was functioning and Pump 2 completely failed. This a dual swash plate piston pump HPK055AT Hitachi pump.
I have swapped the Speed Sensing fluid solenoids to see if that was an issue, but no change. I tested the pilot pump pressure and it is around 725psi, so I don't think it is a pilot pump problem.
It seems that this is most likely a faulty rebuild and the swash plates are not actuating, but seems odd that both sides would be stuck.
Has anyone else had a similar issue or have any suggestions?
Thank you.
Thank you.
