Just remove the spool from the section. Depending on what section you are working on there is a hole in the spool that you can place a punch through to hold the spool and loosen the spring retaining bolt (it is NOT left handed thread). Just be careful if the hole is in the finished part of the spool make sure it does not leave any ridges at the hole that could cause the spool to stick. If the hole is in the reduced diameter section of the spool you don't have to worry about that. When assembling, then the spool is in the section and and the seals are installed with the spool in place. There is a special tool to put the seals on with (JDG734).
Thank you! Got the spring screw out the way you suggested.
The shop which overhauled this the first time installed the poppet and spring in such a way that spring (#13 above) flared out and they sandwiched the valves together with part of the spring out of the port. This galled up the valve body.
When I brought it back to them, they replaced the bent spring with a bigger spring. But the poppet was wedged in the bore (unknown to us at the time). When dissasembling it today, the poppet put up a fight coming out. The others just dropped in. I'll be ordering a Deere spring on Monday. Below is what they had installed.
The big oring between the valve sections measured just a tad smaller than the seals we got from Deere on Friday. Not sure if they were just compressed or if they were actually smaller. They're maybe two months old.
Also, they didn't replace the wiper seals and the inner seal was just an oring. I don't have the seal kit yet to compare, but the service manual shows a special looking seal with a flange on it, not just an oring. Even this oring wasn't very snug around the spool. The valve bodies were dirty, gritty and poorly assembled. Really disappointed in $500 I paid to have this done.
It will be cleaned thoroughly and internals coated with hydraulic oil before it all goes back together.
Any other suggestions? We plan to make sure the galling has no ridges or lips on it. Will this have any affect on things after it goes back together. I figure the big oring between sections should prevent leaks, but the way it was leaking before, the big oring looked okay, just perhaps undersized.
