JD410Jersey
Hello ...hope someone can help,I was running my 410 moving dirt had no troubles parked it and went to use it a week later to find my loader had very little to no power to lift the bucket and the the backhoe will move but not very fast ... steering is fine and the machine drives fine... turning the steering back and forth will help to make the bucket raise.hydraulic oil level is fine, about 6 months ago I replaced hydraulic oil and filters used jd hydraulic oil and cleaned the foot long screen...I opened the plug on the pressure control valve and checked the spring out it wasn’t broken... I bought gauges to test the hydraulic pump and on my outlet pressure I’m at about 1000 psi and my inlet pressure is 0 psi. I can not figure out how to raise it.anyone familiar with these machines or have any recommendations on what else it could be ? Thank you Chris
