S.Moore
Hello, the problem I'm experiencing is very similar to the issue that was being discussed in this thread.
I just purchased a John Deere 690DLC Excavator that has an issue operating when under control of the system controller. It works useable with the computer control bypass switch on. When in computer control mode it will work properly for a few minutes before idling down to low idle and engine speed control becomes unresponsive. If I push the "I" (Idle) mode button, the hydraulics work about like they should for being in idle. The three other modes have little to no hydraulics at all. (swash plate responding to system controller but not throttle perhaps?)
When I run the computer's self diagnostic by pressing the button on the controller, I am able to test and adjust the low Idle speed. When I press the button again to proceed to the high idle check, the system controller revs the engine up to high idle for a minute or two before idling down and throttle becoming unresponsive. All the lights and buttons on the console appear to work normal, but no change in throttle speed. If I shut the engine off, throttle speed will work again, until I go to high idle for a few minutes, then back to original issue. In the time when the throttle is working under computer control, the excavator works great in all modes.
Reading the forums here I suspected the engine speed sensor. However, it tests good according to the technical manual (TM1508) as far as ohms go anyway. Next I tested the engine speed control actuator solenoid. The tech manual says it should read 26 ohms, my meter reads 6 ohms. I'm thinking that this solenoid is failing as when it throttles up. As more power is fed to the solenoid, it gets hot and too weak to maintain pushing force on the hydraulic speed control valve. This sounds like a great place to start replacing parts, except John Deere and everyone else wants over $1200 for this little thing. It's hard to spend that when I'm not 100% sure that'll be the thing that fixes it.
I did order a similar solenoid off eBay for $120. It is the same manufacturer (Magnet-Schultz), throw (2mm), size (35mmx35mm), bolt pattern, voltage (24v), only difference I can spot is the mating surface lacks the o-ring groove of the original. I'm betting I can make it work.
Any thoughts or comments?
The excavator's serial no is 565900
I have TM1508, Operation and Tests manual
All fuses are tested good
I have not yet tested any other sensors/solenoids/relays other than the engine speed sensor and throttle solenoid.
-SM
-SM
