John Deere 690elc
Babsfarms
Croton
Hello there
I was wondering if anyone has tried operating a John Deere 690 with microprocessor removed, I can’t find one so we were wondering if we could make it work without one just wondering if anyone has tried it
Thanks Taylor
Babsfarms
Croton
Hello we can’t get the pump to stroke with the bypass I didn’t know if maybe there was some wiring we had to jump?
Diesel Dave
Ontario Canada
No wiring to jump.
See screenshot of bypass valve block below.
When in bypass mode, the adjustable regulating valve on top of the bypass valve block reduces the pilot pressure going to the hydraulic pump allowing about 65% output.
Babsfarms
Croton
Yes we did that and put gauges on before and it was set at 145 psi and then we had a cab fire and installed new cab but all I have is the cab controller no microprocessor installed so we were thinking maybe it needs one to even work in the bypass mode
Diesel Dave
Ontario Canada
Have you checked the pressure since the fire and replacing the cab ?
