John Deere 70D
Tags
Connecticut
I would try the muffler bearing first, If that doesn’t work, I’d run to the store and grab a can of compression and see if that does the trick…
Vetech63
Oklahoma
Hello. I have a 1998 JD 70D. I need to change the flux capacitor on it. Any tips? I may also need to renew my fusion licence with the NEC.
You can only do this properly when performed after 2 episodes of SpongeBob and a juice box.;)
TVA
USA
If everything above wouldn’t help - you can try to add a bucket of ignition sparks to a fuel tank!!!
CatKC
North MO
Getting a can of compression is a good idea but I would also get a flux capacitor patch kit and patch the leak first so all the amps don't leak out.
4x4ford
Las Vegas Nevada
aunts on the strip Currently drive a 1951 chevy pa
Don’t forget your replacement electrical system smoke
