Scott McFadden
I’m working on a Linkbelt 130 X2 excavator (13005NJHEX1288) The machine tracks fine, but the boom down joystick control doesn't work, but all of a sudden, randomly will. When the function does work the boom goes down at full speed/force. You can’t ease the control. All joystick controls (excavator swing, bucket curl, etc.) do the same thing, but the boom down function is by far the worse.
Pumps 1 and 2 reading 350psi on the screen.
I tested the outlet of the charge pump assembly and it was reading 700PSI. I tested after the hydraulic filter just before the 4 bank solenoid block. It also was at 700PSI. Both hydraulic filters did not have silver or debris in them.
Any suggestions? Thank you.
