Evening all,
A friend of mine has the above mentioned loader. Was going forward in 2nd gear then lost all drive. 1st and 3rd worked for a moment then loader came to a stop. At the same time, the park brake light on the dash has come on and cant be turned off. There is no power to the park brake switch. Have checked fuses on the right hand side of the cab and all are ok. There are two lights on the 'ecu' tucked under the right hand side of the cab, EA & BZ. No idea if these have any relevance, or if what im calling the 'ecu' would have any effect on the operation of the trans.
Any help or suggestion would be much appreciated.
