I dug a ditch and was returning back to where I started when the engine died and there was no power anywhere, just like turning the key off. It appears as though there is no power coming from the battery relay. All connections are good and you can short across the 2 big terminals of the relay and get power to the console in the cab but it still won't crank the engine. I am going to put a new battery relay on it tomorrow in hopes that that will fix it. Took old one apart and it "looked" good. Any other ideas in case that doesn't work?
