GregsHD
Hi,
Have an issue with the RH drive motor, track locked up solid with no warning. Popped cover off and checked final drive as oil was very black, found no metal and looks good. checked pressures at drive motor test ports. 3500 psi in forward, 1500psi reverse, also with the gauge still in the forward port but the travel lever in reverse i'm seeing over 500psi.. I'm thinking problem in the counterbalance valve on the motor? It's a Nabco brand motor, numbers off the plate are 23V00001F1 and below that, A7 3 0550. Machine Ser is YNT 0568, Grey market so I have trouble getting specs from anywhere. I don't have much experience with drive motors and there systems so any help is appreciated!
Thanks,
Greg
Thanks,
Greg
