Kobelco sk210lc-10 machine was recently stuck in a wet area. Mud was up to the bottom of cab. Machine was moved out and is in a limp mode. No codes. Everything is functional except swing and throttle. Track movement is also very weak. Swing tries to move and can hear the engine bog a little if holding to one side, as if the swing brake is not releasing. With the emergency mode switches I can make the display show swing unlocked but still the same symptoms. As for the emergency throttle mode we get nothing machine will only idle. Everything else seems to be ok.
Someone told me it could be the mechantro controller but before I go to throwing parts at it, figured I would get other opinions.
Any helpful things to check or specifics on components to check for readings prior to ordering parts.
