dingo
im trying to fix a komatsu pc300-7 hydraulic fault. when i compound function boom raise and arm in AND boom raise and bucket curl at low idle my boom stops. At high idle it slows the boom considerably. Boom movement returns to normal when other functions are relieved. i have removed and inspected the boom and boom hi compensation valves, they look slightly worn but servicable. the boom shuttle valves are working and the boom spool isnt damaged. Safety suction valves look ok. Merge/divide valves seem to be ok but i believe boom and arm run off the front pump. LS pressure and pump output pressure are within spec. I am convinced the compensation valve is faulty but i need to make sure before i change it out....any ideas???????:Banghead
