JayBee59
Hello all,
I have taken delivery of a reconditioned Komatsu PC50UU-1 Sn1825 (see the one I purchased here
I have only driven the thing for 12-15 hours since delivery a few weeks ago.
On 04-02-23, I shut the unit off as normal. The next morning, I initiated the glow plug procedure, but no response from the key switch in any direction. I checked the fuses. All good. I tried jumping the battery with my F250,. The jumper leads arced as if I had accidentally reversed the polarity. I then used my Dewalt 30AMP Automotive Portable Car Battery Charger with 80amp engine start and alternator check (Home Depot). The unit's processor couldn't display anything. I then disconnected the battery and reconnected the Dewalt and it began charging the battery without any problem. The battery showed only 9.2V and the Dewalt went into "recondition" mode immediately.
I then removed the control/starter panel in the cab. All connections were intact with no apparent issues. In the engine bay, the battery is well grounded to the motor mount and is a clean metal to metal contact.
This excavator has run perfectly for 12-15 hours with no hesitations or power issues. The machine is slow to start in +/- 35F temps (using the glow plug procedure).
I have very limited electro mechanical knowledge. Might anyone explain the "reverse polarity" effect I experienced when attempting a standard jump with HD cables? Did I lose a ground further up the chain of contacts? I wish I would have paid more attention in "electrical for dummy's" class!
Thanks in advance for any help you may lend!
