Mark A Weiss
I suspect a sticking starter solenoid. Do these machines have a propensity to this problem?
The other day, I was moving some logs and while I was using my chain saw, I shut off the machine to save diesel. Five minutes later, I go back in the machine and try to start it and a faint "click click" and slight dimming of the idiot lights is all I get.
I opened up the engine bay and tried tapping on the solenoid with a small crowbar, but it still would not start. So I figured maybe I can jam the crowbar between the terminals of the solenoid and "jump start" it, but all I got was a big spark and burn craters in the end of my crowbar.
A few minutes later, I was able to start the machine normally.
Is this hot start no crank issue common on these machines? Is solenoid replacement an effective solution?
