mike69440
Komatsu PC75 UU-2 I threw Track , Adjuster is stuck solid.
Tried to use the bucket to push back the adjuster. Then a 5 ton hydraulic jack against the blade.Very little grease came out where i removed the check valve Lubricator. Yoke is rusted.
I have not tried soaking in penetrating oil. As there is an O-ring at the front of cylinder, I'm not sure wrapping a soaked rag around the yoke will get me anywhere.
I do not dare loosen that big cylinder nut. Spring does not look like it can be compressed in the field.
I'm fairly sure if i try to pump out the yoke, the seal and yoke will be destroyed. if i can push it back in, the seal Might survive?
