komatsu transmission
jughead
soddy-daisy tn.
retired
1977 d75s front trans yoke need advice on removing it. tried a small puller didnt work. looks like 2 bolts hold it on the shaft from outside. if nothing holding inside will get a larger puller. need help please. i have the shop manual. doesnt look like anything inside the trans.
Countryboy
Georgia
Load Out Tech. / Heavy Equipment Operator / Locomo
If all the bolts are removed and there are no other fasteners (snap rings, clips, etc.) I'd say go for a bigger puller. If that doesn't work then you might try a large slide hammer. I've only pulled yokes on pickup trucks before, but if the yoke and shaft are splined then it should come off the same way.
Could we get a picture by chance?
jughead
soddy-daisy tn.
retired
d75s
i have 3 exploded views of this trans. nothing is show inside to hold the yoke. i dont have a camera. cant get my son here to post pics. if positive there is nothing inside to break would get what ever puller it takes to get it off. dealer in chatt town says have to pull trans. i have a problem with his suggestion needless to say.
Countryboy
Georgia
Well, definately take the dealers advice over mine, because mine's just a guess at best. Not saying the dealer's advice is correct.....just not sure about mine either. It must not be a standard press-fit yoke or there is something else that needs to be removed. :beatsme
jughead
soddy-daisy tn.
retired
d75s
thanks for the replies going for a bigger puller tomorrow. i have worked on vehicles for 40 years just cant see one would have to pull the trans to remove a yoke.
jughead
soddy-daisy tn.
retired
d75s
My bet is that there is a snap ring on the inside jughead.
it acts like it but the book doesnt show one. the pics in the computer seem to be very clear. there are 2 snap rings inside but they hold something else and do not show touching the yoke at all. just hard to believe one has to pull that big unit to change the yoke.
jughead
soddy-daisy tn.
retired
d75s
you are rite. found a guy at the dealer that could use a computer. dug up some excellent pics. i made a jig and drilled the bolt out. i really helps just to talk about some of this stuff. gets one thinking kind of makes the brain work a little better. thanks guys for the help you made a big difference and kept me from screwing up big time.
Countryboy
Georgia
So what's with the guy who said the transmission had to be removed....or maybe they would've removed the transmission for easier access to the snap ring. :rolleyes: :D
Glad to hear you got it.
jughead
soddy-daisy tn.
retired
d75s
one more thing. i am just beginning to realize how expensive this yellow paint is. when i started in business over 40 years ago in auto motive repair i have rebuilt passenger car automatics for what ONE u-joint cost for this thing. no wonder dirt pushing is so expensive.:drinkup
Wulf
Yeah... you didn't really explain why you wanted to get the yoke off. Was it just the drive shaft bolts broken off in the flange?
jughead
soddy-daisy tn.
retired
d75s
would have been easier to drill out the broken bolt in a drill press. my wife says i never make myself clear. sorry.
