masterwelder
Just got a 057-5 with the factory hydraulic pin grabber. It’s also the 50th anniversary badged machine. Came with a few features- air seat, rear camera, keyless start, two line hydraulics.
I had a 057-5 before this one just couldn’t deal with the old style manual coupler any more. I went to the dealer iso an after market manual pin grabber. We found Kubota just loaded all the part numbers for the 057-5 factory pin grabber. Long story short I had them fit it to a new machine on the lot.
Finally Kubota has seen the light about pin grabbers. I know the 040 has had it for awhile. Nice to have it as a factory option. I hope it becomes available on all machines.
Works just like most of the other pin grabbers, hit the switch and curl the bucket. Can reverse buckets as well.
Only issue so far is they blew it with the thumb. It is so far off the stick it makes digging in a deep hole very difficult. Called dealer and they said they contacted the rep. Haven’t heard anything in two days. I can’t believe Kubota let this go like this. I have no faith they will correct mine. The thumb of course is different do to the coupler so someone had to design a new one.
It’s an expensive option to add the pin grabber and thumb combo to the machine. At this point unless they fix it, I would hold off. If I have deep digging I’m going to have to remove the thumb, get a shorter main pin and cap lines.
