kUBOTA 4540 A air into hydraulics on backhoe
ecm2004
NH
I have a Kubota 4540A tractor with A Backhoe and within 10 minutes of useing backhoe the hydraulic sytem starts to foam and will not work.
It has to sit for a while before I can use again!!
Any suggestions would be appreciated !!
Thanks
ecm2004
NH
Yes Fluids are full and It was working fine! I have not had the tractor that long!
Thanks
AllDodge
Kentucky
With fluids full and aeration happening, I would start with filter and pickup screens and connectors to see if air is leaking in. Hope the pump does not have a leak. Its doesn't happen right away, only after it heats up and things expand
Have you posted this on orangetractortalk.com ?
ecm2004
NH
No I have not!! I will check out the filter and pick up screen and go from there!! Thanks for the response..
